Gammal 2017-06-20, 09:09
Pepepapas avatar
Pepepapa Pepepapa är inte uppkopplad
Standard Tein Flex Z or Mono Sport? + EDFC
Hi Guys,
I would ask a little help before my final decision of my new coilovers.
I decided to buy Tein coilovers.
Flex Z what i would choose(twin tube structure is better for street).
But does anyone have experince of them, spring rate is not to soft? (7kg/5kg) It would be my first coilover so no idea i have.
Mono Sport is almost double price(Monotube structure,better for track, easier to damage on street) and it has higher spring rate (10kg/8KG).
Please share your experiences to help me for the final decision.
Other thing i tought to buy Flex Z with EDFC active damping control, but i have no idea is it good to spend money on it?
Is it fast enough with G sensor?
What effect does it have for the liftime of the damper because it is in move always? (maybe a solution for lifetime to use it in manual mode and use G sensor on race track only)
Thank you for the help !
Car is impreza STI 2011 sedan
Gammal 2017-06-20, 10:14
Ursprungligen postat av Pepepapa Visa inlägg
Hi Guys,
Hi!
I don't have any experience with either of them but I'm happy with the Tein coilovers I have tried Would think the Flex Z is nice on a street driven car because they are a bit softer
Have you considered Öhlins Road and Track?
https://www.ohlins.com/product/road-...2007-2011-grb/
Guessing better support with lots of knowledge closer than for the Tein coilovers And I would guess easier with spare parts further down the road!
Nothing bad about Teins, just giving you options
Gammal 2017-06-20, 10:22
Pepepapas avatar
Hi!
Hi,
Thank you for info, Öhlins is a bit expensive for me
i use the car in every 3-4 weeks (somethis more times).
Trackdays maybe 1-3 times a year.
Do you know the 10kg/8kg hardness how should i imagine? It kick my ass on streets or can be used on street but will be a little bit harder?
Or the same for the flex z which is softer- what should i wait of it? Similar like the original or harder/softer?
Thanks for the help!
Sent from my SM-G930F using Tapatalk
Gammal 2017-06-20, 11:11
Last time i checked, I think they retailed for around 25000 SEK s (the Road and Track version) so shouldn't be that big of a difference compared to the Mono Sport?
Sorry, don't know what spring rates I had on my coils but from memory of other persons experiences I think 10 is a bit stiff on the street
Hi,
Gammal 2017-06-20, 11:32
Pepepapas avatar
Thanks for the info,
Maybe i would lean for hks hypermax 4 gt also, but for price and usage flex z what i like, just don't know how hard it is
Gammal 2017-06-20, 11:46
Sounds like a good plan Negative side of the HKS ones are that thay are not intended to be rebuildable if I remember correctly? Might be som older versions though...
Think Goffemannen is running Tein Flex on his GC8!
http://www.subaruclub.se/forum/showthread.php?t=87347
Worth reading the thread and asking him
Gammal 2017-06-20, 11:48
Pepepapas avatar
Yeah you are right, hks is not rebuiltable :/
Tein will be my way.
Gammal 2017-06-20, 12:45
goffemannens avatar
yes I run Flex on my GC8. They work great for the road and a little track.
Vill du ha en snygg film eller bilder på din bil? Kontakta mig då via mail eller pm.
Impreza STI Type R - Superior Media - Superior Imports
Gammal 2017-06-20, 12:46
Pepepapas avatar
Thanks!
Alla tider är GMT +2. Klockan är nu 14:35.
